too much fuel?
Angry Slide
so i took the car for a spin down the street. when i open up wot the exhaust backfires violently like pop pop pop pop loudly then the engine dies. i start it back up and drive it to make sure its ok. i get back on the gas and the same thing happens.
heres the set up. its a cressida with a 7mgte motor, the stock NA ecu, stock 7mgte injectors. was told theres a walbro fuel pump but i never got around to pulling the tank to verify it. i just put in new Autolite 3923 gaped to .30
i dont drive the car, i just start it up and move it around to get other cars in the garage or around the block to make sure its running ok. after a few weeks of starting the car a couple times a week. the plugs foul and i have to replace them. im on the third set of plugs. when i pull them they are black and covered in unburnt fuel.
at idle there was quite a bit of black smoke comming out of the exhaust. so this morning i removed the Jtube and it still has a little bit of black smoke but definetly less than before.
does this sound like a fuel problem since it runs rich and i dont have any means to control it? thank you
supradan22
NA->TER
May 20, 2005
915
ORLANDO FL
It may be because you have the n/a ecu you may want to try to get a turbo one and see if that fixs your problems.
Oh BTW are you still on the n/a electronics like the coil and afm.
lagged
1991 1JZ
new rochelle
he would have to be if hes using the NA ecu...
Angry Slide
yeah, the car came with na distributer, coil and afm... it ran well before. maybe the car just doesnt like the autolite plugs...
