what is you take on oil persure to much for bareings ect what s the idea amonte of persure for the 7mgte
What oil you running?QWIKSTRIKE;915639 said:I get 130+ psi on start up and 20 psi during warm idle, andcreuise at 2800 rpms at 48psi
HommerSimpson;915631 said:Bearing Wash is what i have always called it.. Usally rule of thumb is you need 10 psi x 1000 rpm... So at say 6000 rpm 60 psi would be good.. at 2000 rpm 20 psi is fine...Why they made the 7mgte with such low pressure i have no idea....but it is a high volume low pressure system...... Im fixing to plumb my remote oil filter and cooler.... I used a 3/8 ball bearing in the Relief spring on pump.. Hope it puts it were i want it.. :}
CyFi6;915708 said:I dont understand the idea about toyota making high volume low pressure system. Doesnt that just mean all the bearing clearances are larger and flow more/hold less pressure? If thats the case why couldnt you fix that by running the kind of clearances you want? If im totally wrong, my question is, what exactly about the system lowers the pressure and increases the flow?
AJ'S 88NA;915799 said:You can run larger clearences, I have, on the bearings. Which means to me that you have more oil in those areas as long as you mod the oil pump and anything else you can do to keep oil to the bearings. Somebody please correct me if I'm wrong.
Doward;915617 said:Pressure is resistance to flow.
Any where I can have increased flow, I'm down for
QWIKSTRIKE;915817 said:I wouldn't run larger clearances
But why wouldn't you run larger clearences? Well I guess if you are running that much oil through all that^^ you need all the pressure you can get.QWIKSTRIKE;915863 said:I just shimmed the oil pump, and put on the na adapter with a billet inlet and outlet, and then I am using an inline billet themostat with a Monsta oil cooler from an Australian comapany. The cooler is 13x2x6, and cost $109.00 delivered. The cooler is an equivalent of an Earls cooler for less. I am using a dual Billet.ams oil filter mount which both hold about 2.5-3 quarts of oil. I use 10 quarts of mobile1, and a mobile1 M301, and M403 oil filter. I used to use the B&M 70266 oil cooler, and I believe that although they worke well they may be a little to constricting of flow. I got everything in billet because the cast aluminum pieces were of inferior quality, and was always cracking.
AJ'S 88NA;915849 said:Why is that? If you run a little larger clearence then you would have more oil to those areas. In modified motors you would want more oil in the critical areas, rod bearings in the Supra's case. Of course you have to make sure you still have the volume and the pressure. And run a heavier oil.
QWIKSTRIKE;915873 said:I personally don't believe in running loose clearances on the rods or main berings, but if you feel man enough to do it don't let me stop you. I am getting higher oil pressure with tight clearnces. I usually find the more loose the clearance the more problem you have for knock collision inevitability. 7M's need tight clearances around the mians, and rods. this is done by sending the block and the crank with the main and rod berings to a good machine shop to have each journal done to the tightest clearances.
