Toda Hi lift cams 264 10.3mm(7mgte)
Iron Tank
Grease Monkey
N. California
I have the opportunity get a hold of a pair of Toda 264 degree 10.3mm lift cams in. and exh. Has anyone ever tried running a set like this (10 mm+ lift)ton their 7mgte? Obviously ugraded valve springs/ valve train componants are needed as well as proper clearancing of the pistons. I'd like to hear some personal experience of people who have actually attempted this. Thanks
siman
Lifetime Ban
Murfreesboro, TN
they are just big cams for big air.
you must have a total head package to actually take advantage of them...much less a boost upgrade!
They will idle funky....but they are great on top end.
some people say the TODA's are "untunable"......I find that retarded. They are just HUGE lobes for deep high rpm breathing ( =more HP).
-Jonathan
DEFIANT 7M
101MM stroke of INSANITY!
Nashville/Miami
Stock lift is 7.6mm (.300) the duration is 199 @ .050. So to go to 10.3 (.405) @ ?? duration you will need port work. The reason I say this is the stock 7M head flows almost same number at .300 as it does at .450 +3-6cfm. If it is a great deal get them. Just know you need to do a few things to use them. Are you sure they are Todas and not T.E.D. Components cams (specs for KK108 number 3 below)?
http://www.todaracing.com/products/toyota/camshafts_7mg_specs.html
T.E.D. below:
Toyota 7MGTE Horse Power Quick Kits
Turbo Applications (CUSTOM BILLET camshafts only)
**45-100HP+ gain
1: KK101 : 8.9mm/262 duration
2: KK102 : 9.7mm/272 duration
3: KK108 : 10.35mm/10mm/264/258 duration
4: KK108B : 10.7mm/262 duration
5: KK610 : 11.8mm/288 duration (requires shim under lifter)
6: KK611 : 12.5mm/288 duration (requires shim under lifter)
Iron Tank
Grease Monkey
N. California
I know todaracing.com doesn't show a listing for 10.3 mm lift cams for the 7mg in their site. However i'm quite sure these are infact Toda cams
Iron Tank
Grease Monkey
N. California
I decided to purchase this set of toda cams. I guess i'll just have to start playin around with the spare engine first. Later, i will find out how the stock ecu, hks vpc, gcc + f-con/550 chip setup will react with the use of these cams.
DEFIANT 7M
Nashville/Miami
Iron Tank said:
That thing is gonna be friggin b@d@ss once its completed and running. :cool:
What are the cam specs for that beast of an engine?
:icon_bigg I hope it starts :biglaugh: 12.5mm lift 288 duration (the KK611s)from T.E.D.
fstoy
Soon to be Evil Twin
Texas
T.E.D. below:
**45-100HP+ gain
I am in the market for some cams. Where can i find more info on the above cams.
I did a search on T E D and found nothing.
Thanks
David Z
Iron Tank
Grease Monkey
N. California
Thanks
David Z
Which cam set are you looking to purchase? :icon_bigg
chevyeater
wastegate hose is pulled
Long Island, NY
I wouldn't put those cams in a street car. I also wouldn't try to run them with a speed density piggyback. I have the TRD "Group A" cams in my GTE, slightly more agressive than the ones you are asking about. They make for a pretty poor street car but can be alot more fun at the track.
Use the 1SZ-FE shimless buckets and Ferrea springs and retainers like I did or check out what Allan used in his killer GE. Either way, you'll need to clearance the lifter bores in the head for the camshaft lobes or ovrbore them for larger lifters or something along those lines.
