to those with air horns
WA
i just got the hella air horns so now the obvious question. where the frack can i mount these things? has anyone figured out a place to mount these so they face straight ahead? if so, please post pics.
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
well not quite straight ahead... but ya know how the washer bottle is mounted in the side in the cubby hole there.... well the other side is a big empty hole... i made a bracket and bolted them on it and then bolted to there... works a treat :)
cwapface
Supernerd
Eugene, OR
www.dylanwiggins.com
I just did this on Saturday, I'l post pics. With the K&N filter, I managed to fit both horns around the intake piping and they are in there solid from tension between the pipes. Nice and loud too
KeithH
Portland, OR
I just used the stock horn mounting points - made things nice and easy. Just make sure to point them down at least slightly so water doesn't go into the horns.
I LOVE those things. Everytime I have to honk at someone they really jump. So much better than the little "twink" of the original horn - I still can't believe they would put such a weak horn on the Supra.
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
How did you guys install the air horns? I've been wanting to do this for SOOO long! You must tell me!!! :D
I will be installing mine on a push button switch, someone please fill me in.
WA
summit sells a kit.
