My motor has been bored .05 over. i have heard that is bad, but how bad?
87supraturbo19 pearl white Jan 16, 2006 360 0 0 38 Springfield,MO Feb 6, 2006 #1 My motor has been bored .05 over. i have heard that is bad, but how bad?
Justin727 T-virus infected Mar 31, 2005 2,849 1 0 GPT/BILOXI, Ms. www.crescentcitysupras.com Feb 6, 2006 #2 that would be .050 over. Yes that is the most u can bore it over. Dont screw it up or you will need a new block.
mcpcola 7M's = Peoples Champ Jul 4, 2005 428 0 0 44 Greater Gulf Coast Feb 6, 2006 #4 if cut to much you will get poor heat transfer and if you scare the walls that block is toast
Justin727 T-virus infected Mar 31, 2005 2,849 1 0 GPT/BILOXI, Ms. www.crescentcitysupras.com Feb 6, 2006 #5 just keep it tuned well u shouldnt have a problem. i have seen a few 7m's bored to the max with 2jz pistons in them
shaeff Kurt is FTMFW x2!!!! Staff member Super Moderator Mar 30, 2005 10,589 10 38 Around Feb 6, 2006 #6 keep it in good tune, as justin stated, and make sure your cooling system is up to par, or above par. -shaeff
