to keep it or scrap it
what to doooooooooo
  • fabricate someplace new for the resvoir
    Votes: 5 83.3%
  • deal with it
    Votes: 1 16.7%
  • smaller turbo
    Votes: 0 0.0%
  • Total voters
J
JerzeySlowpra
Guest
i've run into a problem with the t70, the power steering resvoir is probley and inch and a half or so away from it with no room to get anything onto the 4` inlet... should i keep it or scrap it, i've drivent he supra with out p/s before and oit wasnt THAT horribly bad... keep in mind this is not a daily driver
SupraNBama
Anniston,Alabama
i would agree try and relocate it instead of removing it unless its completely necessary...have u tried a n/a resivoir? i got a friend that put a n/a on his turbo supra b/c his stock one was in the way to
J
JerzeySlowpra
Guest
i didnt even know there was a differance, i can look intot hat
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
Ya for sure just use the NA version bro. That's why I bought one because it locates all the way to the left side of the bay, near the tower I believe? Anyway, it gives you a straight path infront of the turbo to use for piping. And as long as the resivoir stays above the pump you'll be fine because it uses gravity to feed the fluid.
eric
shaeff
Kurt is FTMFW x2!!!!
11
Around
relocating is easy as pie. if you dont want the resivour in the N/A position, you could always put it between the radiator support and the front of the car...
-shaeff
