the ECU always thinks the timing is set to 10deg BTDC
if your engine is worn and needs say 3deg advanced the ecu does this however still reads 10deg BTDC when you put your strobe on it, so if you advance your engine to 15 you could efectivly be running 18-20, its up to you.
