timing jumper???
sleepersupra
i hate this car
Nov 5, 2005
311
Broken Arrow, Ok
ok this is gonna sound stupid but when i bought my car it doesn't have a diag box that you can use to check your timing but the wires are still there and i wanted to know if anyone could tell me what color the wires are that need to be jumped that way i can check my timing.
thanks,
Mike
sleepersupra
i hate this car
Nov 5, 2005
311
Broken Arrow, Ok
jkbmkiii said:
Well that seems to be the best part of my wiring harness, and I dont want to break the plastic connector, sorry but I cant help!
you cant see the bottom of it where the wires connect... if not i appreciate the help
jkbmkiii
539
Castle Rock colorado
Took a little work but I got it apart! I wish I still had the parts car wiring harness, would have been way easy!
try Red with a black stripe+ Red with a green stripe....?
sleepersupra
i hate this car
Nov 5, 2005
311
Broken Arrow, Ok
jkbmkiii said:
Mine is a 88t, I have yet to check my timing since the dyno, but with out it jumped you wont be able to change anything...
i know but will it read the same? as far as letting you know where it's at? cause without jumping it mine reads 15 and if i adjust the cps it'll move either way
jkbmkiii
539
I would use the one I gave you that you know is the same and then just jump the rest one at a time , you will know when it works as your check engine light will flash
