Timing Jump?
eviltouge
25
Socal
my timing is jumping so whats that mean?do i need to replace the timing belt or i need a new timing belt tensioner? need help guys becuase i need to smog my car.
figgie
Twin Cities, Minnesot-ah
nope and nope
timing is a fucntion of a couple of things. See jetjocks post off timing in the ECU subsection. Usuallly the jumping around is FINE as TSRM states 10 degree + - 2 degrees.
jdub
Feb 10, 2006
10,730
Valley of the Sun
That's a bit different than timing jumping around ;)
It's likely the tensioner is bad or should have been adjusted before the belt jumped a tooth...it's in the TRSM. Since you're gonna replace the belt, get a Toyota or Greddy belt.
Tanya
1,851
Naples, FL
*sigh*
the timing belt could be stretched due to age, tensioner could be bad, OR your timing gear keyway is starting to go bad, and its slipping, making the belt jump teeth...
eviltouge
25
Socal
Tanya said:
*sigh*
i guess your right i might as well change all of them then
thanks:icon_bigg
eviltouge
25
Socal
also i have another question can you still drive if the timing jump? does it do any internal damage and any damage to the cat.?
