Piratetip;2094501 said:Maintenance interval is listed for the timing belt in the TSRM, along with everything else.
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=MA&P=2
Every 60,000 miles.
Better replace it soon, valves don't like to kiss the tops of the pistons.
It is called an interference engine for a reason.
Cp2295;2094499 said:What he said. Most 90s engines were belt driven whereas most 2000s are chain driven. Belts were used to reduce noise, advancements in engine design have resulted in less noise and the use of chains has been brought back also due to the fact that manufacturers wont have to warranty them. (For the most part-some chains have recalls on tensioners).
