I found the cause of my issues. I think the timing belt is slipping. I align everything and tension up the timing belt. I start the car, it runs fine for a second, then gets progressively worse. I turn it of and check the alignment to find everything way off again.
I've redone the above many times. Is it possible that the tension components might not be functioning correct, allowing the belt to slip?
How would I fix the above problem?
