The engine i got was disassembled and i'm in the process of putting it all back together. Does anyone have any pics or whatever which shows the how to install the timing belt?
Throw it on counterclock wise, piston #1 at zero on the cover (tdc) and cam gear dots alinged with the marks on the back cover.
There should be no slack going from the crank gear, to the intake and exhaust cam, and the slack between the ex cam and the crank gear. Install tensioner, and your done.
