landtoy80 said:Is there a way to remove the timing belt cover without removing the rad hose and fan belt?
Have you put a timing light on it? Like yota said it could be off a tooth. A timing light would tell you.landtoy80 said:It was running fine until I removed the leaking distributor and installed the rebuilt dist.
I tried several times to get it started but it ran rough. I just wanted to remove the cover to see if the timing belt is still in time.
88YotaTurbo said:uhm Timing is checked by the crank shaft anyways. I know what you mean. First What did you do? and How is it running?
AJ'S 88NA;767664 said:Have you put a timing light on it? Like yota said it could be off a tooth. A timing light would tell you.
Frank Rizzo;969656 said:And to anyone who runs no timing belt cover, you have balls, or no brain, or both!!.
Poodles;970467 said:I find the rubber gaskets only seals once...
YMMV
