Hey all,
Well I finally figured out my Clatter Problem that Ive had for a long time. Since I have installed alot of Upgrades to my car, I was told that I need to have my Cams Adjusted.
If I set the Timing at the correct Setting 10 Deg.... I start to get Valve Clatter as though Im low in Oil. Now If I move the timing back to 5 deg the clatter is almost non existant but a little Slugish when taking off.
Since I cant get the timing back to the correct Specs, What do I need to do to correct this. The cam Gears are still in the Center Hole.
Should I try and move the notch to the left or Right?
Robert
Robert
