ticking sound
mk3concepts
1j on the way!
Apr 2, 2006
268
Bay Area, Une Town
ok i have like a ticking or clicking sound..its not loud, i know its not a rod knock. the ticking gets faster when engine is reved. don't know what it is..any suggestions?
mk3concepts
1j on the way!
Apr 2, 2006
268
Bay Area, Une Town
ok ive searched..im thinking its the valve clearance..pretty sure..i 4got already..i gotta go back and search again..but thats my guess..just one question..is that a major problem? cause people on this forum say its common..just want to make sure
staticpat
Supra Chair!
Birmingham, AL
After I repaired rodknock I can hear this ticking now too. I guess the knock overpowered it before. My buddies new 7m has it as well, so its probably pretty common.
Just stick your head next to the cylinder head, you will defintely be able to tell if its coming from valve lash. Re-doing the clearances is time consuming but not too hard. There was a guide somewhere on how to do it without removing the cams.
ERA
1,934
any way the wind blows
Ive just recently discovered it. Hopefully over my spring break I can apply the stuff ive gathered from SupraCentrals write up on diagnosing rod knock.
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
mine started knocking simply due to wear. it wasn't contamination of the oil through water, or debris. sometimes its just time, and therefore your stuff should be salvageable. just use your shit.
mk3ftMFw
Mini Toon Burnout!! FTW!!
Jan 24, 2007
95
Cincy
I was told it was the exhaust, the valves, and even the cams acting up. Here's the deal, it was neither.. rod knock. Rod knock before it actually becomes a "knocking" sound is a tick. A tick is the first step until it devlops into a much louder knock.
Mine has been diagnosed as a rod knocking when all it is, is a slight tick. Dont be fooled by the usual.. "its your loose manifold" , or " your valves are ticking refer to your TSRM" . You'll be lucky if its any of those.
