Tial BOV question
Justin
Speakers?
Spokane, Wa
my tial bov will hover about halfway open at idle. That just means I need a stiffer spring correct? I have the 9psi spring. Now, the idle is at 2500 becuase I have not got around to getting everything dialed in correctly. This is the first time the car has ran since mid summer and the first time with the from.
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
You can try shimming the spring before you decide to buy a heavier one.
I've never noticed mine open at idle. (silver spring, no idea what rate)
As long as the pressure on the valve though the vac. port is strong it should still hold in boost while in + pressure at the manifold.
I assume you're speed density.
Justin
Speakers?
Spokane, Wa
That is a safe assumption. I am running MAFT Pro in speed density.
It has a dedicated line off the intake manifold, and the line is hardly 14 inches, if that, so it has a great source.
americanjebus
Mr. Evergreen
wa.
I may be wrong but i believe that our vacuum pressure requires that you run an 11psi spring on the Tial for it to work properly on our cars.
Justin
Speakers?
Spokane, Wa
Thanks guys... looks like i'll be buyin an 11psi spring here soon :)
I'd rather just get the right spring than shim it.
