so i went to check my codes, and i came up with code 14, it says that it is an ignition signal error, either the igniter, coil pack, or the ecu, but how could i check to see wat is malfunctioning? please and thanks
Go to the search part and type in code 14. I did it and there are 27 threads started about that. I didn't read any of them, I just made sure that someone else had had your problem before. You should be able to find your answer in there somewhere..........................lol, good luck.
