Threaded o2 sensor?
johnathan1
Supra =
Aug 19, 2005
5,056
I just put on my 3-inch downpipe...but I had to have a flange for the stock o2 sensor welded on to it...
Well, the muffler shop that I took it to (despite their good reputation) did a shitty job, and the flange cracked as the nuts were being tightened...:nono:
Luckily, the flange has threads in the center, meaning I can use a threaded type o2 sensor w/out problems,instead of taking the dp off and taking it back to the shop for the third time...
I remember reading a while back, that the Mustang sensor from Autozone will work? So which threaded o2 sensor will fit and work correctly?
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
ok i reread your post after about 20 times and i found that the cracked the flange heh. perhaps you could use a bolt/nut combo with longer bolts and by putting your nuts through the downpipe. iunno thats just me but thats what i would do w/some loctite and everything would be fine no?
Mr.PFloyd
Jun 22, 2005
3,964
alright then. ill try to find you that page for the threaded o2 sensor.
edit bro,
ma71supraturbo said:
Any universal 3-wire bosch sensor will work (as a threaded -- not for stock fitment). You should be paying around $25-$35 for one that is universal. A little more for one that is intended for an application (with a plug on the end of the wires)
