Well I'm going to be rebuilding a GTE from the bottom up, head and block decked ect. When I rebuilt my N/A I got an Ebay Gasket set for 50.00 and used everything from it except the head gasket.. Everything worked great and is still working great. I will be using a HKS MHG on the GTE however I was wondering If anyone has ever gotten one of these and used the timing belt or water pump from it? Im not worried about the pistons,rings, or bearings as they are NPR and ACL or King.. A Timing belt from Rockauto is less than 20.00.. The biggest thing I would be worried about is the timing belt in this kit.. Use it or not, This wont be a high power engine just stock turbo with exhaust and the boost upped to 10-12 lbs with a SAFC for tuning.
http://cgi.ebay.com/ebaymotors/87-9...rQ5fTruckQ5fPartsQ5fAccessories#ht_2794wt_939
So should I get an autozone, myers, or rockauto timing belt or just use what comes with this rebuild kit..
Thanks
Thanks
