Just wondered if anyone has any thoughts on this.
Car is in the shop, because we "assumed" the CT26 was shot. Getting 57 Trim/exhaust/injectors/etc... (all except intercooler upgrade at this point)... because the turbo failing was what I was waiting for to upgrade that.
So, they pulled the exhaust and oil "poured" out of the turbo. Pulled the turbo.. a tiny tiny bit of side to side (I think thats normal) and no front/back play. Spins nicely.. so looks like the turbo is solid. Pulled the manifold (going to have to helicoil all but 2 studs) and oil is dripping out of the exhaust ports (they are wet inside). The 6th port (near the firewall) is dry.
Now.. the car has been sitting in the shop for 2 months and they have done startup/move the car/shut down for about 2 months, so it may just be the valve stems are leaking and that is just oil build up because of not running much. Could be rings, but I doubt that because the last leakdown and compression test came out very good. (about 4000 km ago)
Told the shop to go ahead and pull the head to see where its coming from, but wondered if anyone has ever seen this?
