miggles said:is the factory vacuum source non vsv interupted?
jetjock said:It cuts off manifold vacuum and vents the FPR to atmosphere for about 90 seconds after a hot start. The ecu uses the coolant temp sensor to decide when to do it. This raises the fuel pressure to supress vapor formation and assist in hot starting. Unless you're boosting within 90 seconds of starting it's not an issue. Hook it to a full time vac sorce if you want but you may experience cranky hot starts.
