This is bugging the crap out of me!!
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
Alright guys here it is,
Drove my car for a week with no problem at all. next morning i go to drive it.......will not start.
The car cranks very strong but will not turn over. now ive searched for the past week and worked on the car and cannot get this thing to start.
things ive already done.
Checked for spark (good)
checked and swapped in a diff afm
swapped in diff EFI resistor pack
All grounds are good
Battery (good)
Alternator (good)
Compression is 140 psi across the board
Swapped in a diff TPS
Full Tank of gas
Fuel pump is good (aeromotive a1000)
Im getting fuell pressure at my regulator
I checked and made sure i have fuel at the rail
Swapped in a good wiring harness
Im getting voltage at the injector clips.
ALL fuses are good
All relays that i know of are good (swapped in a bunch of them)
New spark plugs and yes they spark.
After crankin i did check the plugs and they aredry (no fuel)
I did check to see if my injectors are making sound or pulsing. i get nothing their dead silent. so the only thing i havnt checked is my Injectors which i am takin a couple to get tested later on today. but it bugs me that how could all of a sudden 6 injectors stop working! I c
Also im getting a code 51.
Im lost and loosing my mind
Any help is appreciated.
thanks
-saif
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
Rajunz;1380680 said:
Well, you know it can't be all 6 injectors, You have fuel at the rail, so it sounds logical that more than likely they are not getting a pulse from the ECU.
I would start here.
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=FI&P=83
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=FI&P=49
I had an extra injector laying around, so i plugged it in to my harness and yo can feel the injector working! so the inj are gettin pulse.
Only thing i cn think of is redo the timing again.
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
You could have an intermittent break in a wire. Did you wiggle the wires?
I have seen this more times than I can count. A mkiii drives somewhere then won't start. I would wiggle/move any wires that you can see.
It's easy...just do it! ;)
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
Can someone take picture of this fusible link, i cannot find it in my car.
