thinking about goin single
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
what manifold do you single 1jz guys use? and where do you get them from? i'm thinking about goin single cuz i have a blown stock twin? does the 1jz have problems spooling big singles?
Ric
Setting the standard
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
I run this manifold:
http://manictechracing.com/mtrloru1jmat.html
I also run a GT40-88 turbo. Full spool by 4k. I rev my motor to 8k. No problems at all :) It starts spooling almost off idle, its very responsive.
A 1JZGTE spools a turbo a few hundred RPM later then a 2JZGTE (1-300), but we have a higher redline, so it evens out.
Be a man about it, and at least get something with a 65+mm inducer :)
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
the ebay ones are fine you just might have to modify a bolt hole or two and modify the WG tube
tissimo
Stock is boring :(
Melbourne, FL
My ebay manifold fit fine.. The wastegate tube was too long though, so cut it off and welded a Tial 44 flange on it.. never any probs..
I had the stryder manifold..
