things fixed and new problems show up yayyyy
Skam9685
1992 Honda Prelude SI
Jun 22, 2007
157
Oldsmar, Florida, United States
Goods- Well I replaced the spark plugs with NGK Iridium Laser Series, fixed my A/C and turn signals. Replacing the spark plugs fixed my eradic idle and the engine now runs smooth as silk, my A/C now blows cold and turn signals now work. Waiting on the NGK Spark Plug wires to get here that i bought from CKanderson.
Bads- Upon replacing the spark plugs i found out that spark plug 1 had oil on it. Research in the service manual stats that oil deposits on the spark plug means oil is leaking past worn vale guides or piston rings. So i now know that has to be inspected. Well i take the car for a drive and it seems as though the automatic tranny is slipping gears because 2nd gear is pulling slower than a mother f'er. We recently had a car done with similar symptons so im thinking its the valve body. One of the fuel injectors is leaking (im assuming cant really see that well at night lol or even know if a fuel injector can leak for that matter...still new) which would give me the gas smell and why my gas mileage is so bad. I beleive it is what is making the car stall as well because not enough fuel is reaching the engine. The injector is making a hissing noise like from a soda.
If any of you have comments feel free.
Skam9685
Jun 22, 2007
157
the oil was WET oil that was on spark plug 1....to fix the A/C i just used A/C sealant to stop the leak the compressor had and then i just put more refrigerant in it....the A/C now blows colder than hell lol
more than likely there was some oil in the plug valley from leaking cam cover seals that got on the spark plug.
you can make the fuel pump come on through jumping 2 ports in the diagnostic block under the hood, I forgot which and can't find it right now. Doing so will show where you're leaks are...
Auto trannies aren't my forte...
