Thicker than suppose HG? Ok or not?
sylquebec
167
Quebec
Hi, here it is:
Machine shop remove .1mm from my head and i remove .05mm of the block from lapping it. So i should need a 1.5-1.6mm thick headgasket. The fact is that i already have a brand new 1.9mm thick cometic headgasket in stock.
Is there a problem if i use it?
I know it will lower the compression, but does it will lower it enough to be a problem or i should not worry about it?
Thanks to let me know!
Smartparts
146
CT
Don't quote me but stock headgasket is 1.37 mm compressed I thought. Since you took off .6mm and you have a 1.9mm hg that should keep you right around stock compression.
suprarich
Guest
Nov 9, 2005
2,187
ohio
It will not really change anything to use that 1.9mm. Toyota has used at least 3 different oem thickness head gaskets over the years.
Lower compression will just have slower low end. Run more boost and the top end will be great.
