The joys of home ownership.
Jun 6, 2006
2,488
12
Amerika
www.dreamertheresa.com
I'm getting ready for work (Mike's long gone), and I keep hearing water running.
I look and look and look; nothing's on.
I go downstairs to open garage to leave. Hm. Sound of running water MUCH louder.
I open the side door.
Giant pool o' water in the driveway. I investigate.
Hm. Spring of water has sprung and there's a little fountain beside our house. Great.
Called water company. It's our problem.
Called work. See ya.
Called plumber. "We'll be there between 2 and 5!"
So here I wait.
At least the house is getting cleaned.
:icon_mad: :icon_mad: :icon_mad:
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
Sorry to hear about that. The plumber will be there at like 4:30 then say he doesn't have the right tools. Happens all the time with the maintenance for base housing. Good luck though.
Anth505
Failte
Apr 8, 2007
105
Toronto Ontario
Depending where the leak is coming from you might not get dinged for it. If it is leaking from the pipe that goes from the watermain to your house and is leaking before the meter, you're good. If it is leaking from anything after the meter...ouch!!
Good Luck.
I once had a toilet overflow and it not only flooded my basement but all the ductwork for the furnace as well.
Ahhh...the joys.
Jun 6, 2006
2,488
12
Amerika
LoL!
Logan doesn't like men coming near the house when I'm home alone.
I suppose he can be a bit intimidating.
SO! $500 later...
We have that crappy blue poly plastic B.S. that will need to be replaced ASAP. Anyone have $3k laying around?
SupraMario
I think it was the google
The Farm
Did you at least turn off the main shutoff valve?
And BTW the intimidation goes out the window with those homo blue flowers in the back ground....:p
Those homo blue flowers aren't what I would be worried about. It would be the canines of Logan and the barrel of Mike's 45.............:aigo:
If this plumbing problem is going to get in the way of Vixen and I being invited into the hot tub then I'll be over there to fix it in the morning DT...............:naughty:
Dec 3, 2003
6,653
Canada
Yup! I love having to pay bills like that....NOT
I have 2 trees from the city on our front yard and we are not allowed to remove them. The roots have gone through the sewage piping and guess who had to pay for that bill? Yup..I did :cry:
Duane
Supracentral
10
No need to do anything like that.
But what if they got sick and died?
Re: How do I kill a tree without cutting it down?
http://www.ag.uiuc.edu/archives/experts/fertility/0637.html
"I hope I'm not out of line here with my amateur advice...
One method I have used to kill trees in-place is to 'girdle' it.
Remove the bark, outer and inner, all the way around, and for a foot
or so from bottom cut to top cut. I'm not sure if it works on all
types of trees, but I have used it on oak, poplar, and pine - made it
much easier to handle when I got around to making firewood
out of them.
Another way would be to clip the roots with a sub-soiler, but there is
danger of it falling unpredictably.
With the girdling method there is another advantage. Once tree is dead
it can be felled by fire. Pack thick ring of mud/clay above girdle and
do a slow controlled burn of girdled area - you can direct the fall
almost as well as with axe or saw."
In Reply to: how to kill a tree
http://www.bobvila.com/wwwboard/messages/219002.html
"Spray the leaves with high concentration of urea/nitrogen
(fertilizer) on a sunny day. Nitrogen will burn it( but not like
fire). Make sure that when you spray, it will be totally wet. Use
powerspray for big trees. If the leaves will not show a sign of
withering and burns after a week then add more urea/nitrogen to your
next spray (be patient or use 50 kilos of urea per tree if your not
that patient. UREA IS NOT TOXIC TO THE ENVIRONMENT (uhum, I HOPE)."
Re: copper nail to kill a tree
http://www.madsci.org/posts/archives/aug98/904075390.Ag.r.html
"Yes, if the nail is big enough to harm the base of the tree. It can open an
entry for infection and disease. You also need to consider how big is the
nail and the tree. Driving a copper nail has physical, chemical, and
biological actions playing together. If the tree dies, it will not be easy
to know precisely what the main cause was acting. Copper as a metallic form
is not harmfull to tree nutrition. It needs to oxidize, to solubilize and
then be absorbed. Absorption of copper at the bark level may not occur, while
high levels of copper ion in the soil rooting system may lead to toxicity. Many
species of trees also will respond differently to this stress related to
nails in their bases. In biology we do not play yes/no answer!"
How to Kill a Tree by not Watering Enough
http://weather.nmsu.edu/hydrology/treewater.htm
"Trees need water to survive and when they don't get enough water,
they die back slowly. The willow tree below has lost the bark on half
the trunk and 50 percent of the branches have died because it was
watered only once a week to fill the well around the tree to less than
an inch."
Q. Can I Kill a tree just by paving around the trunk?
http://forestry.about.com/cs/arboriculture/f/kill_treepave.htm
A.
"Paving the ground above a tree's roots can kill quickly.
[edit]
Just pave right up to the tree's bark."
Fill Can Kill A Tree
http://hort.ifas.ufl.edu/gt/fillkill/fillkill.htm
Will salt kill a tree?
http://davesgarden.com/t/256979/
"Tough question, not enough detail, but it can. If you use a large
enough amount and don't flood it but water it in, it will cause the
roots to lose moisture and become unable to take up moisture and
nutrients. I once had a mean neighbor who, for reasons yet unknown to
me, poured salt around the base of my cherry laurel hedge. It was at
the back of the lot, and I didn't go all the way out to it often, so
the salt sat there and worked its way into the roots. The grass died
first, and when I went to examine the area to determine why, I noticed
that the leaves on the shrubs were becoming mottled and streaked, with
yellowing. In a matter of less than a month, they all died. I saw salt
around the bases of all of them, and later a neighbor kid told my son
who put it there. I am not certain it was table salt, but given the
mentality of that person, it probably was the most common and readily
available form. I tried watering excessively to flush it, as well as
pulling back the soil and mixing compost into it, to no avail."
[edit]
"I have an old pine tree on the other side of my property that is
blocking My view and I would like to know how to kill it with out
having to chop it down. I dont think salt will do the trick? I've
heard that a copper nail would do it but that does'nt work either
I have tried that... and that DOES work! But then after I did that,
everything else I planted there, kept on dying! So, I have never did
that again!"
[edit]
"The guys who trim my trees cut down a large tree for me, cut deep
holes in the stump and poured some salt into them to kill it
permanently. I was worried about the salt going into my soil. They
said to cover the stump with aluminum foil, secure the aluminum and
just leave it there. I was worried about the salt going into my soil
and they said it would be absorbed by the stump. The stump rotted
enough to be taken out and there were no ill effects from the salt. I
am not saying to do this because maybe I was just lucky the salt never
made it to my soil. Of course the stump was in an area that I could
leave it a long time without having to remove it.
To kill a tree without removing it you can just girdle it: remove the
bark in a band all the way around the trunk. It could possibly survive
if the cambium manages to stay alive, so you may want to scrub/scrape
the band after you remove the bark."
Re: How do I kill a tree without cutting it?
http://www.backyardgardener.com/treeboard/messages/890.html
"Well, you could cut out a section of the bark totally around the
trunk of the tree. Do it about 6" wide. The tree will be exposed to
the elements and won't be able to recover. This will take at least 2
to 3 years to kill the tree. Best to just cut them down for safety
sake. I don't use poisons so I can't help you there."
Q. Can I kill my tree by eliminating the fertilizer?
http://forestry.about.com/cs/arboriculture/f/kill_treefert.htm
A.
"On the contrary! Double or triple the recommended fertilizer rate.
Fertilize your tree often and double the recommended rate, especially
during dry conditions.
Recommendations for fertilization of trees vary considerably. From
young trees to mature trees, the amounts vary. Foresters and
horticulturists generally agree that nitrogen is the only nutrient
needed in most cases. So go ahead, give your tree a quick shot of a
fast-acting, complete fertilizer on August 31st."
how to kill tree without cutting it down
http://forums.gardenweb.com/forums/load/woodland/msg0213282514048.html
HOW TO KILL A TREE STUMP
http://www.co.st-lawrence.ny.us/Cooperative_Extension/forestry/26killastump.html
http://www.bobvila.com/wwwboard/messages/215368.html
"cut the tree close to the ground. drill several holes in the stump,
paint stump with full strength roundup and fill the holes with
additional roundup. there should be no sprouts growing from the stump
or underground roots after this treatment"
