The Improved Slow66 Build Thread...
Status
Not open for further replies.
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
Well, frankly my other build thread had a bunch of pictures of crap that i did that i either ended up changing or ditching all together. Well, I finally have my shit together and have a SET plan on how I am going to actually finish this thing. I had alot of stuff that i was going to do like a de-stroke, and run on methanol (which i will still do both eventually), but I want to actually DRIVE this thing at some point, so I'm going to run what I have on gas and just try and enjoy the thing. I've committed to working on the thing on a regular basis again, so i ahve some new progress as of today. So heres the whole build (3 years going....) in a quick rundown. Most of you have seen these already (theres some new ones at the end though :) ) but the goal is to have this thing make noise in the spring... I know, i know, thats what i said last year too....
Anyways heres the pics for those that may have not seen them before...
Started out life with me as a stock 87 turbo auto with a bad knock...and was promptly gutted completely.
Ordered some stuff up from a redneck catalog...
And then got happy with a sawzall....
Started fabbing...
Roll cage time...
Sprayed Purple....
Rear tinwork...
Lexan...
Cams. 288 duration 12.5mm lift. Stock on the left.
Slow66
Apr 3, 2005
1,457
Newington, CT
Got crazy and decided to tube the front, mostly for space. The fuel cell and turbo are mounted up front.
*latest progress* Mounted up the turbo. It has been in 3 other spots before this. This one is permanent :)
Next up, header fab (again) and Intake manifold, with all these goodies...
Stay tuned!!
Slow66
Apr 3, 2005
1,457
Newington, CT
For those that may be interested in the motor plans, here they are:
Old plans: Destroke, custom aluminum rods (which i have already and will sit on the shelf for a while) 11.5:1 compression, 3600cc injectors, Methanol, the cams i showed earlier, Big Stuff 3 engine management and dry sump oiling.
Plans i will go with so i can actually finish in this century: Stock crank, Pauter rods and Ross pistons ive had laying on the shelf from previous motor, same cams as above, 1600cc injectors, racegas, Big Stuff 3 engine management, and stock oiling (with improvements)
Trans is a powerglide with stright cut gears and a ~5500 stall converter and the Ford 9" w/ 4.30 gears and a 30" tire...
I think thats about it for now.
suprarich
Guest
Nov 9, 2005
2,187
ohio
Darn it Bryan, I just used the last fully race preped stock crank I had. Send me your crank if you want me to fixed it up.
Nick Stonawski
403
Manhattan Beach
Its not real till i see it make a pass with my own eyes at SILV. There is no 7M on this planet that can produce more power than 300HP. i could only get 299.8 out of mine back in the day. Your clearly reading too many of those redneck magazines. :biglaugh:
Glad to see u get back on the horse. I'm really anxious to see this thing move already! And from an asthetic standpoint.... u know a turbo on the other side of the bumper would really balance things out too. :sarcasm:
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
I'd call this a bit more than 300HP.
http://www.gtepowered.com/index.php?page=html/gcurmi/profile.php ;)
Slow66
Apr 3, 2005
1,457
Newington, CT
F&H Performance;1122530 said:
Looks great Brian, dont forget what we spoke about in texas you need anything, I mean anything make sure you call.
Will do!
suprakid24;1122556 said:
Subscribed, awesome build. Did you do all the tubing and stuff yourself? Again, that's awesome.
Everythign but the paint and machine work was done by me :)
Yeah, i gotta give you a call...I need a girdle too :) I just picked up some billet mains for a decent price...
Nick, I'm saving that for when i blow up the 7M a few times and then go to a 1/2UZ with twin 88s :naughty:
Great job Brian. Call me if you need any help degreeing your cams............;)
Noah, I bet their rental got better gas mileage............:biglaugh:
Status
