The Best Tune-Up
jessetooslow
551
Tiverton, R.I.
So I finally got my headgasket job done , now I wanna do a tune-up, what do you gusy suggest I should buy, the oil has been changed as the tranny has been serviced when I bought it, what should I do, to run better?
Kckazdude
1,239
Memphis, TN
I am sure there is some cheap ass that will disagree with me but I think a standard Supra HG job would include: head gasket, VC gaskets, int and ex gaskets, cam, oil pump drive seal and crank seals, t-belt, thermostat CPS/distributor o-ring and plugs. There may be more but that is the bare minimum to me.
Short answer to your question, yes.
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
Kckazdude;987918 said:
I am sure there is some cheap ass that will disagree with me but I think a standard Supra HG job would include: head gasket, VC gaskets, int and ex gaskets, cam, oil pump and crank seals, t-belt, thermostat and plugs. There may be more but that is the bare minimum to me.
That sounds like almost an engine tear down to me once you go replacing oil pump seals, which I'm not even sure what they are. Are you talking about the black o-ring around the cps shaft?
eric
