2 things that I do know about the test pipes. I have Trents old Cat Back on my car now with a High Flow Cat. When he had it he took the Cat off and put a Test Pipe, and it made the car quite a bit louder. Also, You will loose bottom end and gain WOT, but if you drive the car alot, you will probably want the bottom end more than the WOT.
