Tems
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
ok my 86.5 has tems but how do you get the third light to come on when you push one button its got one light you push the sport button its got 2 but how do you turn on the third one? i know its working cuz you can here the actuators engage?:naughty:
jkbmkiii
539
Castle Rock colorado
mine only showed two also but if you where cornering hard the 3rd would go on and off, dont know if that is the way they work , just what mine did!
Red Dragon
Keep That on the Down Low
Jan 5, 2006
318
Austin, TX
oh i thought you were kidding or something.... cause you have 522 posts i just assumed you were, no biggie.
Yes, you can only lock TEMS into hard with an aftermarket controller (like my HKS, but a few others are made, getting hard to come by) otherwise the sensors will put you into hard only when it "thinks" you need to be in hard such as under hard braking, high speed, lateral g forces, etc... otherwise sport only locks you as high as medium, and normal of course just soft...
shaeff
Kurt is FTMFW x2!!!!
11
Around
post count has nothing to do with the amount of knowledge that someone has. ;)
-shaeff
trydrew
Suprafied
Nov 4, 2005
1,038
Earth
isnms said:
TEMS Firm Override, Cockpit controlled FIRM mode
studying the wiring diagram, it can also be done completely inside the cabin. i'd have to search around for the post.
Ive done this mod, and it works but i havent road tested it - BHG. It does work to get the thrid light to go, but you feel kinda bad that your backwiring it all. But, ive heard no problems in doing this, so i assume it is safe. I ran the wires through the top of the diagnostics block, because i didnt want to tear away any of the wire protection. Then i ran it to a cockpit mounted switch for easy on/off activation. Its pretty cool.
I could give you pics if youd like, just ask.
-shaeff
Of course it does!! I thought youd have known better shaeff, considering that your a genius! w/ your ~2000 posts. :D
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Yep, in the stock trim it only goes on under the conditions mentioned ie; anti-dive, anti-squat, and anti-roll.
Anti-dive is sensed off the brake pedal switch, anti-squat off the TPS, and anti-roll off off the steering wheel optical sensor.
In normal mode the sport mode (2 lights) will also come on when vehicle speed exceeds around 80 mph.
