Tems
SUPERIUM
Low Postage Member
Nov 29, 2005
171
Buffalo, NY
Can't you just ditch the actuators all together and turn the lil dial on top of the strut (probably need to use some needle nose pliers) to set it at the third stiffness level?
That seemed like the easiest solution but never heard anyone mention it on here.
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
pretty sure you can. There is also a way to trick tems into locking into full stiffness all the time with some easy wiring. There is a little more to it than that but if you want to know just ask.
SUPERIUM
Low Postage Member
Nov 29, 2005
171
Buffalo, NY
Figured that would be the easiest route without having to splice wiring to trick the tems comp. and the engine bays a bit more cleaner without the actuators. Just kind of suprised no one ever mentioned to do it this way.
