no. it should just go away when filled... the sensor in it might be stuck or disconnected or something. If you want you can remove the overflow bottle with like 2 bolt and look in it to see if the floaty thing is loose. just double check its still full too cause the car will suck the fluid out of it when the block and radiator lets out the bubbles from the system.
