Agreed. The AC fan uses the temp switch on the thermostat neck to turn on the auxiliary fans when the ac is on, AND when the temp is over 160-170.
If you use this ground for a simple relay to control your fan Then the fan will turn on only when the temperature reaches 165 degrees or so. I have not tested my switch to find the exact operating temperature, but I do know that it is a happy temp for the 7m to run at and it is a prime way to have your fans turn on when they are needed. Also by hooking up a fused direct power source to the relay, the fan will cycle on and off until all of the coolant is below 160 degrees, reguardless of ignition switch position.
That way, even after your turbo timer has cooled off the oil, your fan will continue to cool the coolant until... well until its cool.
