Tell me if you think this could be a HG issue.
da89soup
World I Am Gay Blue!!!
Dec 2, 2005
1,978
Fargo ND
When you rev up the car can you see white smoke out the tailpipe????? Is your car overheating??? Are you noticing any antifreeze usage???? Can you smell antifreeze when its running??????
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
you sure its not the cam cover gaskets? On something this old and dirty I would think it could be hard to pin point it to between the head and block or anywhere for that matter.
I have replaced the VC gaskets, oil pressure sending unit, Dizzy o-ring and I am still getting oil from somewhere...I saw it like it had been sprayed onto the exhaust heat shield.:aigo:
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
if its on the heat shield then it would have to be above where the block and head meet...it could be the oring on the distributer, mine is leaking there though its on a turbo so I don't have a distributer but should have a oring but its not spraying just dripping down.
supramacist
1,501
The Grassy Knole
Dude...., this sounds like the blind leading the blind. LOL.
Go to orielly auto and get some oil dye. Take your blacklight after cleaning and driving for a bit. It'll lead you right to it. I am so glad these cars are easy to work on. Good Luck.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
take a pressurewasher and some engine brite (be sure to cover and avoid all electrical connections) and clean up the engine bay real good. then try to spot where the oil spray is coming from. if not, then grab the oil dye.
supramacist
1,501
The Grassy Knole
Yes I agree. UNless you can see it when you clean it and that means the engine bay, as well. Just clean it up with dw40. Wipe everything. The cleaner it is the faster you'll locate the leak. If you foul out, the engine dye is under 10$, ya falla.
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
I have that problem... OMG!!!
i have BHG????
