Seven M said:no if boost IS falling off then it'd be a boost leak which could be caused by the BOV.
if the boost ISN'T falling off then its something with the WG or boost controller.
MDCmotorsports said:...... To a point. You see, there is a theroretical point at which the pressure inside the manifold or exhaust housing reaches the spring/mechanical pressure of the wastegate itself.
Sure it could be in the 40+ psi range, but sooner or later the wastegate will open.
