I've done some searching here and haven't found exactly what I'm looking for. I've developed what appears to be a very common oil leak from the distributor o-ring. At first I thought this was being caused by the oil sending unit as I didn't use any teflon tape or thread sealant when I first installed it. I removed it and used a sealant, but the leaking has persisted and appears to have worsened. Upon further investigation it appears that the oil is coming from a source higher up on the block and I can't think what else it could be other then the dizzy o-ring. So here's my question. I've read on cygnus on how to set the #1 cylinder at TDC without removing the timing chain cover and it makes sense. What I'm wondering is how do you know for sure, after spotting the cam lobe through the oil cap location, that you've rotated the engine exactly 120 degrees back and then exactly 40 degrees forward without a degree wheel? I don't want to wreck my timing by not being able to tell how far I've rotated the engine. Is being approximate good enough here? I wouldn't think so, but the cygnus site makes me believe that is the case by offering this option to get to TDC. Is there any other way that works better? I'm tired of this oil leak and I'm hoping to get it square tomorrow. Thanks ahead of time all.
BTW: 1988 7MGE in a 1994 Toyota pickup
