as it started to rain hard here....my targa is starting to leak again.....i did a search and found out that the seals are usually bad and/or bolting it up incorrectly. the targa only drips on the passenger side rear where the targa meets the body...is that the rear seal or what? i want to order some new seals but i don't want to get the entire set since only that part is leaking....i've already took the targa off and sprayed it with silcone treatment...and got better but still only drips. doesn't splash when i brake or anythng...so u guys think its the rear seal or the right hand side seal? if i don't use the targa at all is there anyway i can just take it off and put some silicone on it w/o making a mess on the roof? or d you guys think its the bolting procedure that i should redo?
thanks
thanks
