tapping from the head?
dirtlord420
just here
Aug 1, 2005
371
tn
ok on my 89 n/a. it sounds like the tapping is coming from the head? it tappes at ilde and when you rev it up it slows starts tapping faster. am thinking valve? if so how long could this last? while i have my extra head rebuild. or could this be a rod knock? could this be a seious problem? thanks
MKIIIChucky
101
south jerzy
when your cars at idle look down at your crank pully , i throught i had a valve tap on my 1st engine but later on i found out that the crank pullys keyway splitt n took out my crank n pully , soo when ur cars at idle check down there n see if ur pullys boucin around !
Chuck
89 , N/A , 5 speed ,on my 3rde engine n lookin 2 go N/A-T.....
bensn8
68
Guam
I had the same problem. I opened it up and checked all the valve clearances, they were all ok. I still had the knock so I thought it might be sticking valves, since I had to remove the head anyways to repair this I just decided to replace the head with one from Topline. Still had the knock and then BAM!!! I lost the #4 Con Rod. After opening the motor up I learned that the nuts on the con rod had backed themselves out completely. Drop the oil pan and check better to be safe than sorry.
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
i had one of those knock things. then i went to a supra meet. their eyes went from another member! to uh oh... i have rod knock now :(. So i might rebuild plus BPU or 1jz during winter. Good greif charlie brown.
