dbsupra90 said:
to be honest, if i were gonna go thru that trouble i would just helicoil it. much stronger and easy to find the kit.
AAHAHAHA
HAAHAHA
lol dude to tap out the IRON block you can not do with just any run of the mill bit especially the coated crap. You need industrial sized and forged bits.
Like the 10.8mm Drill bit i bought. Cost me 45 bucks but took out the sheared thread chaser like it was aluminum
Same thing applies to the tap. get the cheap shit that is not high speed steel and you WILL break that sucker while threading and then you will curse yourself for not spending the money on the correct parts first.
and absolutely pointless to even think about helicoiling when you just need to clean the threads so the studs go in all the way!
