Tap size for the 7m block
figgie
Twin Cities, Minnesot-ah
hmm now i know that we posted this not even a week ago.
<-- checks to see if SM crashed, nope. Search still works
but IJ is right
12mmx1.25
Sears does not carry and more than likely no autopart store will carry it. You need to special order it :)
8,898
That is my kind of answer.
JimR
Canada
Edit: I read "exhaust threads" by mistake! My bad. The info below is ONLY for exhaust threads.
mcmaster-carr is awesome for this stuff! I just did this a couple months ago.
Here's the info:
mcmaster.com
Part # 91732A822 for the repair kit which gives you everything to tap the holes (plus a couple inserts but I don't recommend them since they're non-locking)
Part # 90296A343 for authentic helicoil screw-lock inserts
Have fun!
figgie
ummm
we need a tap to CLEAN the threads in the BLOCK NOT to enlarge them!!
Anyway most taps will not put a dent on the cast IRON block. Especially the cheap shit. If it is not High Speed Steel (HSS) it WILL break.
7M's have a bad habit of cracking the block between the Headbolt Holes and the steam holes after being surfaced if the holes aren't chased and then chamfered during a rebuild.
The idea of a chaser is it doesn't remove material just the crap in the hole, a Tap will do the same thing if you're very careful and use lots of wd40 or crc and keep an even load on both sides of the Tap Handle (NOT use a wrench to turn the Tap)
