I have a 1987 Turbo. I installed a Tanabe medalion Exhaust bolted to a LIPP elbow and the down pipe is touching the flooboard near the speedometer cable and at the rear end cross member. Has anyone had this problem and if so how did you fix it?
Dan_Gyoba;1942481 said:I have the Tanabe Hyper Medallion, a Random technology downpipe and the LIPP elbow. The exhaust was originally installed in my '89, and is now in the '90. No problems with clearance, using 3 hangers in the back. (The RT downpipe has no provision to use the front hangar by the transmission mount.)
superwhite;1942459 said:I have a 1987 Turbo. I installed a Tanabe medalion Exhaust bolted to a LIPP elbow and the down pipe is touching the flooboard near the speedometer cable and at the rear end cross member. Has anyone had this problem and if so how did you fix it?
