Taking out the motor leaving the trans
curtismoff
10
jacksonville fl.
:1zhelp: Any tips on taking out the motor and leaving the trans[5 speed] in the car?Do I still need to unbolt the crossmember.It looks like a promblem will arise clearing the oil pan to release it from the tranny's bell housing.Should I just say screw it and take the trans out as well?
DaSuprawolf
Im SICK of N/A
Dec 29, 2005
456
ChicagoLand
when i did my rebuild i left the tranny in the car and it was a pain. when i was putting it back in, i pulled the tranny out just to mate it back to the engine before putting it back in. alot easier. screw bell housing bolts!
curtismoff
10
jacksonville fl.
There is one bolt on top of the bellhousing that I have been f-ing with for 2 hours tommorow I am taking them both out together.:cry: I have a jdm motor ready to stick in this beast.Wish me luck!
Figit090
Fastest mk3 GT4 1/4 mile!
Jan 7, 2006
1,835
Humboldt County
yeah i hear its much eaiser to remove both...dont feel bad, you'll thank yourself.
and that main upper bolt i think is the main problem with removing them seperately...
plus, you can change the fluids and clean up the tranny while its out...
have fuN!!!
p.s. - what are you sticking back in!? pics? thread? i'm curious...
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Top tranny bolts are easy, you just need to convince your girl that she would like to grease up her arm, slide it up next to a cold transmission, and pull two bolts out for you. :D
On the serious side, pulling the tranny with the engine is SO much easier.
cuel
1,536
Baytown, Texas
There's an easy way to get that bolt. Get 4 ft. of extension and a good wiggler socket. Put the whole car up on stands, as high as you feel safe. Put a jack under the trans., take the cross member out, and let the tail of the trans. down as far as it'll go. Reach up there with the 4' of extension and the wiggler socket, and take that bolt out first. Then get the rest of the bolts, working your way down each side, leaving the bottom bolt on each side for last. make sure your jack is set good, and raise the trans. slightly. Take out the last 2 bolts, and you got it. You might have to gently pry the bell housing off of the dowels that align it with the block, but make very sure you got all the bolts out before you pry too hard. The combination of 4' extension and letting the trans. down makes all the bolts alot easier to get to.
BlindRonin
Where are my pants!
Feb 27, 2006
91
St. Louis Missouri
Like all these guys said if at all possible pull out the tranny as well. It can be a pain to get upper tranny to motor bolts undone and the starter is easier too.
p.s. i used 5 extensions and an air ratchet lol zipped those bad boys right out.
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
it is easier to take both out because you need to lower the transmission to do the top bolts on the bell housing meaning undoing and lowering the transmission so might as well take it all out.
supramacist
1,501
The Grassy Knole
I guess you could pull the head to make the afore stated bolts a bit easier to get to then you could leave the tranny but it's still easier with it out. But you have options. Especially if you have not the tools to pull an engine.
Figit090
Jan 7, 2006
1,835
Humboldt County
that might work if you have a BHG, but if not its a bad idea. you'll be down at least 100 bux for a new gasket, plus the crapshoot of cleaning you have to do for a proper seal. and it might not even help access to the bolt. i dont know that part for sure.
