Ok, I have already posted some info about this ongoing problem of mine. For more info on what the history is here's the original post http://www.supramania.com/forums/showthread.php?t=68682
So to summarize, my tail lights/park lights/interior lights haven't been working, due to the fact when the light control switch is engaged the fuse immediately blows. So today I went through my tail light panels to check for corrosion I found a little but I cleaned all the sockets and bulbs etc. I then went ahead and put a new fuse (15 amp) and turned the running lights on. To my surprise everything turned on and was functioning properly. However, this had happened before so I wanted to make sure it was fixed, (because once before I placed a 20amp fuse and it lasted for about 10 mins.) so I tested the connections with my voltmeter. I wasn't getting a very good reading so I stupidly switched the ground with the B+ on the voltmeter to see if the reading changed. My tail lights then went out. Now for the part I am having problems with... I checked the fuse and it hadn't blown like I expected when the tail lights went out. The interior and park lights are still working. The brake lights work, along with every other bulb/filament in the two rear panels except for the tail light filaments.
So here's what I have tried:
1. Checked the fuse, replaced with new, no difference. (no tail lights everything else fine.)
2. Checked the common ground near the hatch release and cleaned, and sanded off the paint under the bolt to insure a good ground. No change.
3. Swapped bulbs to see if maybe (appears I still have my original tail/brake bulbs!!) they were having issues. No change.
4. Got a reading of around 12 Volts from the brake side of the bulb sockets when the brakes were depressed, but no voltage at all when connected to the electrode that services the tail light filament.
5. All bulbs have good filaments including the turn and rear back-up lights.
Here's what I figure it could possibly be and where I most need your guy's input:
1. I know the tsrm says there is a tail light relay in the kick panel. Could this go bad? Did my switching of the voltmeter leads cause it to blow even though the fuse didn't? Does it only control the tail lights only, or the filaments in the bulbs that are set for tail lights?
2. Is my wire (b+), although what was possible to check I did with out ripping off all the side panels, seats and carpet, is it somehow frayed, or exposed? I don't know how this would be the cause since my tail lights did come on, however briefly.
So what do you guys think? What could I try? Am I missing anything?
All suggestions and comments are welcome! Thanks a lot, sorry this is long and I hope it is a post worth your time.
