Hey guys so I was recently doing Shaeff's 12V mod (with no sucess by the way, keeps blowing my efi fuse everytime I crank it over, not sure why??) and after giving up I returned everthing to normal and went to drive my car, and when I turned on my headlights the taillights and interior lights werent working. So I checked the fuse in the kickpanel and it was blown, and replaced (w/ correct 15amp fuse), tried again and it blew yet again. So I looked in the TSRM and the only info it gives is about a Tail-light relay, could this be my problem? Where is it located? What else should I check?
any info about the tail-lights or why my 12V mod isnt working (made sure ground was good, got relay wired up right, inline 20amp fuse, 10 gauge wire, bypassed the fuel pump relay/resistor, also tried with them still installed, same result of blown efi fuse) would be greatly appriciated!!
Thanks
Thanks
