Car = 87 7MGTE on AEM v1, DH61 igniter on stock coils
Does anyone know the voltage on the wire that comes from the igniter to the Tach? I had read that the turbo tachometers received a 12 square wave signal, but I get nowhere near 12v when I volt test the tach wire on the DH61. ( or what voltage range the tachometer is expecting to see)
Some background, I am wanting to convert to 1ZZfe coils, but when you do this you lose your Tach signal as you are removing the igniter. So I used one of the Low Side drivers to modulate a Tach signal but I am getting 12V from the low side driver but when I went to compare it to what the DH61 is sending to the tach I only got around 1V and some change.
I really just want the stock tach to work with this setup, I know some people have gotten it to work but they have long sense left the community.
Any help would be great.
