Tach install
ma70mkiii
139
ohio
I was wondering where can i find the signal wire so that i can hook the tach that i got for my car. its on an 89 1jz. wasnt really sure where i could get a signal at
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
careful tapping into IGF or IGT. If the tach impedance is too low, it will pull the signal low, and teh car won't run.
The correct place to tap into it is the ignitor itself. The ignitor normally sends the signal to the tach. The standard wire is black with red dots on it IIRC.
ma70mkiii
139
ohio
isnt there quite a few black and red wires on the igniter? does it matter which one i tap into?
nctexan
268
Houston
I've tried using an 89+ 7M-GTE tach with my 1JZ (cut black wire w/ red dots) and ran directly to pin 6 of connector A on my dash. Am I supposed to just tap into the black and red wire coming off of the ignitor w/o severing its original connection?
