Can I use studs and nuts like this to mount the turbo to the manifold? The stud will pass through the turbo and thread through the manifold. Will it hold, or just shake loose after time? Would I need to get bolts that would thread through the bottom of manifold up, and mount the turbo on top?
BTW, I'm just test fitting these old studs. I'm going to get new ones. I know I need a gasket between the turbo and manifold.
