T4 Turbo setup info
MDCmotorsports
Indy 500
www.MDCmotorsports.com
You would really like to see a .58 - .68 a/r rear, about a .70 front.
From what I can tell, that turbo should spool about 3500 to 4000 rpm, and I would assume it could make 400 - 450 horse.
A/R stands for Area over Ratio (I think). Basically the size of the wheel in relation to the housing.
In a nut shell...
The larger the A/R, the more lag but the "possibility" of more power.
This can be debated on and on and on.
MDCmotorsports
Indy 500
Those kits are pretty good bang for the buck. One word of caution: The ICs have been reported to explode under high boost, and the flanges on the turbo mani have been reported to be warped when you get them. They also tend to crack because of thier thin material.
Other than that I would say go for it.
QWIKSTRIKE
475rwhp459torq an climbin
Apr 3, 2005
1,172
Some where out there
Buy if you intend on buying again. Quality aint cheap. Go to Turbojoe for good turbo prices and quality.
