I was wondering if anyone has a write up or a list of parts that i would need to build oil lines for a t4 turbo. Also are the same fittings and line lines used for a 7m? if so i can just copy my brothers oil lines. Please let me know thanks!
you can buy a kit that you can put together by yourself from MDC or piece a kit together depending on what you want. the only thing is you have to know what flanges you have for the turbo and what size lines you want to run.
yeah, look at your turbo. I know for garrett's (Tx, GTx), typically the feed in the top is a 1/8" NPT thread, while the drain is a standard garrett drain. (So you just get a standard garrett to NPT adaptor at Summit)
the 1JZ (and 2JZ) block use a 12x1.25mm threaded oil feed, and a standard Toyota drain flange on the pan (which will actually accept a standard Garrett drain flange, so again, Garrett to AN adapter)
I built my own oil lines from a bunch of parts I got a Summit.
