t4 to t3 adapters
  • Thread starter Slow Poopra 7MGTE
  • Start date
S
Slow Poopra 7MGTE
Guest
is there a such thing as an adapter for a t4 exaust manifold to fit a t3 flanged turbo? or anyone have a t3 manifold theyd trade for a new in box t4 manifold, externally gated
williamb82
907
4
Tampa, Fl.
ive seen them before. the flange was kinda thick with recessed bolt holes to bolt to the t4 so that the bolts were flush withthe flange, then had studs in the t3 pattern. if you cant find one i know someone who could prolly make one for you.
william
S
Slow Poopra 7MGTE
Guest
if you can point me in the direction that would be sweet, i tbink i might need one willam
935motorsports
San Diego, CA
I can make these (or have them made). I will guess that you are trying to use an eBay manifold. If so, you need a spacer adapter to raise the turbo.
Let me know specifically the manifold and turbo you are trying to use.
abustiffy
92
in a house
depending on when you need the flange, we should be putting an order in for them within the next few weeks. This was supposed to happen a LONG time ago, but other things came up. Ill make a post when we have them.
